Is this essentially right as far as wiring?
Yup. You should be good to go then. Front channels out of the head unit to the bt 355. Out of the bt355 with rca's into the front channels of the amp input using female to female adaptors. Amp in 2 channel input. Hp on and set to 80. Speaker output from amp left to one cross over and right to the other cross over inputs. Out of the cross overs to tweets and woofs. Set the HU on neutral (bass/treble). Volume at 3/4, start rolling the gain up till you hear distortion and back it off a bit. AVC off and you should be golden.
Anybody got a pic of where they were able to mount hertz crossovers in the fairing? When using the biketronics brackets?
These mlcx 2 tw.3 are 7.75" x 4.75" x 1.6"
I have tried multiple ways, something is always in the way even with the cover off. Not seeing it happen.
Already removed the aux 12 volt connector that was in the way, still no go.
