2017 Sg special ampand speakers
Hey all, need a little advice on a upgrade for my 17sg.
Music type all -upper faring, lower, tour pack when the wife is on.
So at this time, I'm only looking at the upper and lowers..
First thought was to run, Hertz sv 165.1 in the upper and lowers b3 horns in the mirror location. With a bt 250x4 amp kit and there upper faring brackets. But not so sure on how to control the horns.. This set up minus the horns and adding the Hertz millie pro 165.3. Then I called Garage bagger stereo. They say this set up.
GBS SD5
The GBS SD5 kit includes;
SounDigital 800.4 Amplifier
Rockford Fosgate DSR1 DSP
Hertz Audio Mille Pro 165.3 Coax
Metra Adapter Rings for (98-13 bikes only)
979.97
Hertz Mille Pro 165.3
Power Handling - Peak W 200
Power Handling - Continuous W 100
Impedance Ω 4
Frequency response Hz 45 ÷ 21,5k
Sensitivity dB SPL 92
Woofer size mm (in.) 165 (6.5)
Tweeter size mm (in.) 25 (1)
Woofer Voice Coil Ø mm (in.) 36 (1.42)
Tweeter voice coil Ø mm (in.) 20 (0.8)
Woofer magnet High density flux ferrite
Tweeter magnet Neodymium
Woofer cone Pressed-pulp cone with cotton fibers
Tweeter dome Tetolon
349.99
Plug and Play No Flash Complete (14 up SG&RG Only)
2 channel input from stock radio
DSR1 Stealth Harness
DSR1 Accessory harness
GBS2 Harness
14 up pod connections
This kit is only PNP for DSR1 on 14 up SG & RG
With all that said, I am not into tinny sound more of a warm sound.So if this looks good or some thing elses would be better plz toss it into the ring... Thank you In advance.
GBS SD5
979.97
Impedance Ω 4
349.99
GBS2 Harness
I ran the Mille pro. I had a hard time getting them to fit and had to mount them inside the pods to keep the surround from hitting the inner fairing. May like them but I didn’t care for them. They were loud but seemed blah. The tweeters blew out of both pretty quick. Maybe it was my lack of tuning skills. I thought the hcx had more punch, too bad they discontinued them.
Bluesman280
Audio Systems
18
07-09-2017 11:40 PM
