After posting in the touring section about the issues I am having with my HK in my 2011 limited ( flhtk ) and asking for advice for an aftermarket replacement, it was suggested I post over here to where the GURUs hang out.
Here is a link to that thread if you guys care to add you opinions : https://www.hdforums.com/forum/touri...placement.html
Many Thanks,
Over time the mother board often vibrates something loose causing intermitting problems. What does the rest of your audio system consist of? Amp? Speakers? Being a limited is a cb in play?
If you are wanting to keep the cb and all stock then you can send the HU to Iron Cross for thm to repair/rebuild your currant unit. They do superb work and their CS is outstanding.
If you are ready to upgrade the system and by that I mean hu and amp then that is another story. I would not put in an aftermarket HU without upgrading the whole system but it can be done. That's just me though.
