A few changes with setup
Old May 17, 2019 | 08:28 PM
Eric Steward's Avatar
Eric Steward
Default A few changes with setup
Hello everybody,
I'm back at it again. This time I think I have a better understanding of the DSR-1. SO this is what I'm running now.
Front:
Sony ax5000 HU
Arc 600.4 under the hood
Hertz MPX 165 in the fairing
Temporary Rockville mid bass in lower fairing wired in parallel with JL c2 650 in the Tp
Rear
NVX 1000.4
TWO SETS OF JL 6X9 in the bags, lids and inside.
Arc is connected to front output in HU and the NVX IS TO THE REAR on the Hu.
Just picked up another DSR-1 . Will install it this weekend. As far as setting what should I put the Hu and amp on for starter?
Old May 18, 2019 | 07:01 AM
Babyboy's Avatar
Babyboy
Set the headunit so the balance and fade are in the center. Set the crossovers to off on HU.
Settings on amps to full/all pass. Control all crossover and adjustments at the DSP
Old May 18, 2019 | 11:45 AM
Eric Steward
thanks, hopeful I will get a better results
Old May 19, 2019 | 10:54 AM
Eric Steward
Ok, I have a question for somebody to please answer.
Ok, I have two amps no horns and no subs. Hertz 6.5 in the fair, 6.5 in the lower and TP, second amp I have 6x9 in the lids and 6x9 inside the bags. when I go through the setup wizard on the Dsr-1 for the hookups, I see 1&2 for tweeter, 5&6 for rears and 7&8 for subs. So what are the two spares for? when I look at the one figure with the 3&4 being used, I don't see anything for the rears only the subs.
Which one can I use to separate the speakers. the first amp is running the fairing speakers in 1&2 channel and lower and TP is running on 3&4 on my 600.4. on the NVX I have the lids on channel 1 @2 and Inside the bags I have 3&$
SgtMic
Audio Systems
18
Jul 11, 2017 08:13 PM
AdmiralAaron
Audio Systems
21
Jul 28, 2016 07:23 AM
Licopico
Audio Systems
Mar 11, 2016 02:44 AM
kdawg187
Audio Systems
Jan 8, 2016 07:08 AM
jazzyd910
Audio Systems
Oct 13, 2014 07:45 AM
