Flash? what flash...
Old Jun 13, 2019 | 10:26 AM
  #51
eggwhite93's Avatar
eggwhite93
Originally Posted by Jtpntx
okay so now Im going to ultra rookie mode.
This is the amp setting Im using. Per the manual lol
If I try to put either channel in HP it didn't sound good. I tried adjusting some but didn't spend much time on it.
Can you post a picture of the settings on your amp? Or at least a description of where you have the "*****" are set for the filters and sensitivity (gains)?
Old Jun 13, 2019 | 10:30 AM
  #52
Jtpntx's Avatar
Jtpntx
I did in that post. Can you not see it?
here it is again
Old Jun 13, 2019 | 10:31 AM
  #53
Jtpntx's Avatar
Jtpntx
oh wait. "my settings"
I have the filters turned off just as in the illustration.
My input sensitivity is prob at 1 maybe 2 o'clock on the ****.
Old Jun 13, 2019 | 10:33 AM
  #54
SBates08's Avatar
SBates08
Set A&B switch to HPF, set A&B freq filter to 100, turn A&B input sensitivity all the way counterclockwise. Turn volume up to 3/4 (4bars from max), play music from a good credible source (not FM), adjust A input sensitivity clockwise until you hear distortion then back off just a tad. Do the same for input B. Side note, once gains are set, 3/4 volume is now your maximum volume!!!!!
Old Jun 13, 2019 | 10:37 AM
  #55
Jtpntx's Avatar
Jtpntx
10-4. I'll try that when I get home from work. thx bro
Old Jun 13, 2019 | 11:49 AM
  #56
JHC210's Avatar
JHC210
I think my question got lost in the thread. I have an opportunity to get my HU reflashed. Is it worth my time to get my HU reflashed from 4 speakers 1 amp to 4 speakers 0 amp? Would it make any difference? BT4180, 4 speakers, 2 BT line levelers. Thanks.
Old Jun 13, 2019 | 11:59 AM
  #57
FrenchieM's Avatar
FrenchieM
May want to start your own thread.
Old Jun 13, 2019 | 12:21 PM
  #58
SBates08's Avatar
SBates08
Or you could've used the same amount of effort to answer his question.
Yes...change it to 4/0.
Old Jun 13, 2019 | 12:28 PM
  #59
FrenchieM's Avatar
FrenchieM
True but more discussion on his question would maybe get clouded in someone else’s thread or lost
just like his question did. Is the 4/0 the best one depends on your system or ears. Babyboy just did the 4/1
flash on a bike and he said it worked out well.
Old Jun 13, 2019 | 02:58 PM
  #60
JHC210's Avatar
JHC210
Thanks.
