install help
09 streetglide i have the stinger amp and mmats 601 cx 's for the fairing, i do have a tour pack with speakers but they're unhooked until the next upgrade
i wanna try to keep the stock head unit until i can replace rear speakers and head unit at the same time, so for now fairing only
what do i need to hook this up ? i know i need speakers adapters and amp install kit, do i need LOC, RCA cables or anything else ? i wanna order everything at one time, and how difficult is this for a newbie ?
Thanks and any help would be appreciated
You'll need a PAC-SNI35 and a Stinger 4000 1.5' rca cable.
6' section each of 8 gauge wire for hot and ground and an inline fuse holder.
What he said. I will add that this is a very complete amp install kit that will have everything you need (except the RCA and LOC) in one complete kit.
Depends on your mechanical abilities I guess. You are going to have to remove the tank to run the power and ground wires to the battery. I guess that is the hardest part (except for remembering to re-connect the fuel line when you are done
) to the job. Then the tuning fun begins.
