Budget Build Help?!?!
Ok guys you have helped me out immensely and this is what I知 going with.
Bt355
cerwin Vega B52
infinity kappa 6.5
wiring kit mentioned above
stinger rca cables
Final question, with the kappas do I need to get adaptor rings? If so, do any of you have a suggestion of where to buy them/find them?
Bt355
cerwin Vega B52
infinity kappa 6.5
stinger rca cables
Mount inside the pods? Like the factory speaker pods? Also, I知 fine with the 2 in the fairing. So no added speakers.
I would also recommend that you get the HogTunes speaker grills.
Yes, the speakers are mounted to pods, You can split the pods & slightly modify them to install the speakers inside. Good info in this thread https://www.hdforums.com/forum/audio...-mounting.html
Hell yeah! I see exactly what you mean now. Thank you for the wealth of knowledge my friend. It is most appreciated.
