Done!
Old Jul 19, 2019 | 01:14 PM
  #31
GunslingersNation1's Avatar
GunslingersNation1
This is for a pair of Hertz 200L.
To get rid of the whine, I moved the power distribution block over to the clutch side bracket, and away from the RCA connections of the DSP. I have a very slight whine at idle, more like white noise.
Old Jul 19, 2019 | 01:15 PM
  #32
GunslingersNation1
Originally Posted by duglaura&flhti
Was it ON? Fricken Killer Soul Brotha!!!! Congrats.
Blew the inline fuse for the amp. I need to go reexamine my voltage.
Old Jul 19, 2019 | 01:45 PM
  #33
InthewindMN's Avatar
InthewindMN
What amp was the fuse?
Old Jul 19, 2019 | 02:09 PM
  #34
Biggzed's Avatar
Biggzed
Thanks. That's not likely my issue. The search goes on.
Zach
Old Jul 19, 2019 | 03:40 PM
  #35
GunslingersNation1
30 amp. I read the manual and it recommends 2 30 amp fuses, so I'll buy some 60s.
I had my voltage all wrong. I was up near 55 volts! I set it back to about 35, so about 300 watts each. It doesn't get as loud (obviously), but it won't burn up either. In hindsight, I should have bought the 200.1s or another higher sensitivity 8" to focus on the 100hz range.
Old Jul 19, 2019 | 04:09 PM
  #36
FrenchieM's Avatar
FrenchieM
R u sure you didn’t blow them?
Old Jul 19, 2019 | 04:12 PM
  #37
FrenchieM's Avatar
FrenchieM
I cant remember are you running each speaker to a channel off that amp
Old Jul 19, 2019 | 07:20 PM
  #38
GunslingersNation1
It's bridged to two channels.
Old Jul 19, 2019 | 07:28 PM
  #39
FrenchieM's Avatar
FrenchieM
Is that amp bridgeable at 2ohm?
Old Jul 19, 2019 | 07:29 PM
  #40
GunslingersNation1
It's a 4 ohm bridge. Each speaker to two channels.
