Sony better
Old Aug 4, 2019 | 03:43 PM
leadman's Avatar
leadman
Default Sony better
Is the Sony MEX-72BT a better system than the stock Harmon Kardon
in my '12 FLHTK ? Does it have any more power ? It's not very pricey
but I'm still wondering if it's worth the swap .
Old Aug 4, 2019 | 03:51 PM
Fireball Jack's Avatar
Fireball Jack
Yes it is but I dont think you can just replace the head unit. unless you change out the 2 ohm speaker too. One upgrade leads to another until you are all the way down the rabbit hole.
Old Aug 4, 2019 | 07:21 PM
leadman's Avatar
leadman
Thx I hadn't thought about that . I don't see on the website
what speakers it needs . I'll have to check further .
Old Aug 4, 2019 | 07:35 PM
Fireball Jack
Most after market head units are 4 ohm. It really does need to be done all together or not at all.
The amp and speakers can be found in the Classified here if budget is an issue, Some of the guys here change out audio gear more often than they kiss their wife.
Old Aug 4, 2019 | 07:45 PM
Dsm Limited's Avatar
Dsm Limited
How'd you get my wife's number?
Old Aug 4, 2019 | 09:15 PM
Fireball Jack
I graduated from the FBI Profiling class. You checked every box, text book example.
Old Aug 5, 2019 | 11:15 AM
cshocker's Avatar
cshocker
Yes the Sony sound quality and options are much better than stock. You will need HU, mounting kit and handlebar control unit. If you don't want to spend a bunch more on speakers and amp, you can swap out those stock speakers with some cheap/decent sounding Polk or Kicker. Kicker does make a 5.25, but I would suggest going with 6.5" and adapter kit.
Old Aug 11, 2019 | 10:02 AM
leadman's Avatar
leadman
The dealer says the unit works with the 2 ohm speakers .
Old Aug 11, 2019 | 10:10 AM
leadman's Avatar
leadman
This unit is supposed to be plug & play .
Still investigating .
Old Aug 12, 2019 | 12:03 PM
SG-Jay's Avatar
SG-Jay
Unless you run an amp and better speakers you're really wasting your money. Switch to some decent 6.5's and buy an amp. You can do this for a reasonable amount.
