Thundermax and o2 interference
Old Sep 1, 2019 | 05:23 PM
kevfries88's Avatar
kevfries88
5th Gear
Default Thundermax and o2 interference
I have a 17 street glide with the sony 5000 and I put the thundermax in last week and its causing interference in the speakers. It is the wideband o2 sensors causing the problem. Thundermax said they have had customers with this issue before and they had to install a noise filter. So I bought a power noise filter from amazon that had decent reviews, put it on and it didnt help. I tried the constant 12v(yellow) and the acc 12v just to be safe, and neither helped the issue. All connections are tight, the ground is good. The system was fine before thundermax, and if I unplug the o2 harness the interference stops. Does anyone have any other suggestions? I also tried a rca ground loop isolator on both channels, and ferrite cores on the o2 harness and the rca cables with no effect.
kevfries88
2014-2024 Touring Models
Sep 2, 2019 09:33 AM
cajun1957a
Mar 22, 2016 05:31 PM
kamkam2
Jan 25, 2013 05:50 AM
TC96Rider
Apr 1, 2008 06:14 PM
damadman
Exhaust System Topics
Jul 2, 2007 01:09 AM
