Speaker interference with thundermax
Old Aug 30, 2019 | 05:58 AM
kevfries88's Avatar
kevfries88
5th Gear
Default Speaker interference with thundermax
I have a 17 street glide with the sony 5000 and I put the thundermax in last week and its causing interference in the speakers. It is the wideband o2 sensors causing the problem. Thundermax said they have had customers with this issue before and they had to install a noise filter. So I bought a power noise filter from amazon that had decent reviews, put it on and it didnt help. I tried the constant 12v(yellow) and the acc 12v just to be safe, and neither helped the issue. All connections are tight, the ground is good. The system was fine before thundermax, and if I unplug the o2 harness the interference stops. Does anyone have any other suggestions? I see a different type of filter, a ground loop isolator with the rca connections but I dont know if that will be of any help.
Old Aug 30, 2019 | 06:39 PM
Rdcris's Avatar
Rdcris
Maybe try to put ferrite cores on the O2 sensor leads. You'll have to take a part the connector to loop the lead thru the core. or get the split type ones that just clamp around the wire.
I just looked on E-bay they're cheap enough to give it a try.
Old Aug 30, 2019 | 06:48 PM
kevfries88's Avatar
kevfries88
5th Gear
I did see those in my searches but didn’t know anything about them, if they would affect the o2 sensors or not.
Old Aug 30, 2019 | 06:53 PM
Rdcris's Avatar
Rdcris
I doubt they will cause any ill effects. Ferrite cores have been in use for many years and applications. The clamp on type are easy to remove should you notice a problem.
Old Aug 30, 2019 | 06:55 PM
kevfries88's Avatar
kevfries88
5th Gear
I’ll order some. I ordered an rca ground loop isolator to also try since the power noise filter didn’t work.
*cant beat amazon, they will be here tomorrow
Old Aug 31, 2019 | 06:09 PM
kevfries88's Avatar
kevfries88
5th Gear
Tried the ferrite cores on the o2 harness and the rca’s,
no change. Also tried the rca ground loop isolator and no change either.
Old Sep 1, 2019 | 08:33 AM
GalvTexGuy's Avatar
GalvTexGuy
I would post over in the audio forum and see if anyone there can help you. Good luck.
Old Sep 2, 2019 | 09:33 AM
Rdcris's Avatar
Rdcris
It was worth a try? Maybe try the core on the power lead for the ThunderMax?
knlcox
Jun 28, 2013 01:06 PM
Softail Girl
Mar 23, 2010 08:05 AM
tmultra
Mar 4, 2010 09:04 AM
TC96Rider
Apr 1, 2008 06:14 PM
damadman
Exhaust System Topics
Jul 2, 2007 01:09 AM
