What else do I need?
Old Sep 3, 2019 | 10:08 AM
wilburbill's Avatar
wilburbill
Default What else do I need?
I have been rounding up stuff for my 2013 Electra Glide Classic. This is the Classic so it has no CB or rear speakers in the Tour Pac. I also don't run with the Tour Pac. I currently have a Hog tunes amp and fairing speakers that I am removing. I have a Stinger SPX 700X4 amp, Mmats PA 601 CX speakers and WDX Moto G1 speakers. I also have the EBay lowers with the speaker pods. I plan to keep the Harley head unit and send it to Iron Cross for the pre-amp outputs and blue tooth. At a later date I plan to put speaker lids on the saddle bags. I don't have any of the RCA leads, amp power wiring, speaker adapters or any other items that may be needed. I also am not sure if I need a DSP and if so what kind? I am also not sure if I put the Mmats in the fairing and G1's in the lowers or opposite? Any other suggestions would be appreciated. Thanks
Old Sep 3, 2019 | 10:29 AM
Fireball Jack's Avatar
Fireball Jack
Why are you stuck on the Harley head unit. The moto G1's are way to bright if you cant get control of them. You could get a Marine deck with built in DSP, thumb controls and install kit and come out about the sames as a mod'd HK deck. That would give you bluetooth and USB and superior sound,
Old Sep 3, 2019 | 10:41 AM
wilburbill's Avatar
wilburbill
Main reason is my Harley GPS and interface that gives prompts through the speakers. I am also concerned with water issues as I ride a lot and get caught in the rain quite often. If I could get my GPS to work properly I would consider the aftermarket head unit and I guess I could use the aftermarket rain cover that snaps in the hole.
Old Sep 3, 2019 | 11:00 AM
Fireball Jack
With the 13 single din radio what harley GPS do you have, I use Google maps ( Live Traffic ) that prompts my through my speakers.
Old Sep 3, 2019 | 11:02 AM
cshocker's Avatar
cshocker
I'd have to agree, go with aftermarket HU for same price. The Aquatic radios are decent and marine. Complete plug and play. The marine Sony and Kenwood HU are a better option and you could get a radio cover if worried. You will get much better sound out of a aftermarket HU. And Fireball is correct, those DB motos are really bright and you will want an aftermarket HU to tame those down. And put those in your lowers. And NO you do not need a DSP.
You will need power and ground wires (8 gauge, 6 feet each), set of RCA's, battery terminal connectors, 60 amp fuse, speaker wire and 5.25 to 6.5 speaker adapter.
Old Sep 3, 2019 | 11:16 AM
Fireball Jack
This one will work just fine marine grade.It has a built in DSP the moto's cross them at 100hz and-18 slope that is a good starting point. You can sell you old HU and gps and it will more than pay for the Kenwood and install kit.
Amazon Amazon
Old Sep 3, 2019 | 12:31 PM
wilburbill's Avatar
wilburbill
Here is what I have: https://www.ebay.com/itm/283588054743. Mine is mounted on the dash and uses the Harley interface: https://www.shoputahharley.com/produ...26%20Batteries
Old Sep 3, 2019 | 12:35 PM
Fireball Jack
Gotcha. Selling that and you stock HU would cover a lot of the expense of a new system and give you all the new features. something to ponder.
Old Sep 3, 2019 | 12:36 PM
wilburbill's Avatar
wilburbill
https://www.harley-davidson.com/us/e...tech-zumo.html
Old Sep 3, 2019 | 12:38 PM
wilburbill's Avatar
wilburbill
What would be a good HU with blue tooth and XM radio?
