Are you guys using a distribution block when wiring multiple amps? If so which one?
JL makes a great one that uses maxi fuses. It's a little pricey, but it's worth it. The fuses are inline with the outgoing power wire, so if you need to do some rewiring, you can remove the fuse to pull power, instead of pulling it from the battery.
I'm generally a fan of Stinger. The Tspec stuff I see some guys using looks nice too. I had a bad experience with KnuKoncepts and won't use their stuff anymore. May have been a isolated incident but having spent good money the quality didn't match.
Here's another vote for Stinger.
I use the Stinger SPD5625 PRO Series Maxi Fused Power Distribution Block for the Positive connections to My Amps and DSP.
I Use the Stinger SHD21 HPM Series Power or Ground Distribution Block for the Negative connections to My Amps and DSP and I use a Stinger SPD5101 AGU Fuse Holder for the connection from the battery positive to the SPD5625 PRO Distribution Block.
Mike
