Amp settings
Old Mar 27, 2020 | 08:49 AM
hooter57's Avatar
hooter57
Default Amp settings
Got my fairing opened up to paint the inner and was wondering what others have their amp set at. It's a DD d4 amp running Arc Moto 602 speakers and a Sony HU. TIA
Old Mar 27, 2020 | 09:32 AM
JMC22's Avatar
JMC22
There is no one, or magic setting - unless you have the proper equipment I would recommend a simple means: with the bike running, setting your amp gains all the way down, turn the headhunt volume to about 80% max, play a song you like & start to slowly turn up the gains till you get distortion, once you get distortion back off just a hair
Old Mar 27, 2020 | 11:21 AM
hooter57's Avatar
hooter57
What about the HPF and LPF?
Old Mar 27, 2020 | 11:54 AM
Fireball Jack's Avatar
Fireball Jack
HPF this is where it gets tricky the Freq. is key. If you cross at 80hz the gain will be lower than if you cross at 100hz. I have never had those speakers but you need to set the vross overs first before you turn up your gains. What model Sony are you running?
Old Mar 27, 2020 | 12:54 PM
HD_noobie's Avatar
HD_noobie
Arc wants Moto 602 HPF set to 110 , I have mine at 100 and ok so far
Old Mar 27, 2020 | 01:19 PM
hooter57's Avatar
hooter57
My HU is the Sony MEX-70. The HP has no markings. Just says 20hz-5khz. Have the dial set to about 10 o'clock, sounds pretty good just want to make sure before I button this up, for the last time! 😂
Old Mar 27, 2020 | 01:38 PM
Fireball Jack
The last time..... Now that is funny!
Old Mar 27, 2020 | 01:44 PM
Fireball Jack
I think in the HU setting you can set HPF and cross over setting to 100hz. Makes it easier.
Old Mar 27, 2020 | 02:31 PM
hooter57's Avatar
hooter57
Thanks Fireball. If I would stay off this forum it really
would be the last time. And my house would probably be paid for. I blame haze for it all, he got me started down this damn rabbit hole.
Old Mar 27, 2020 | 02:42 PM
Fireball Jack
Yes back in the Day Haze and Gann sent me down the rabbit hole. Alex is a great dude and builds some of the best sled audio in the country.
Wild_Hog
Audio Systems
14
Nov 4, 2019 09:50 AM
Baggergee
Audio Systems
11
Mar 18, 2019 08:32 AM
FLHR2000
Nov 5, 2018 07:09 AM
sevitz5
Audio Systems
17
Oct 30, 2016 07:21 AM
capnkirk
J&M Motorcycle Audio
Oct 13, 2016 10:36 AM
