Educating myself
Old Mar 30, 2020 | 06:54 PM
Pale Horse Rider's Avatar
Pale Horse Rider
Default Educating myself
Just wondering why the MoCo needs three amps and a whole lot of wiring to run 6 speakers. Seems most other options only need one amp.
Old Mar 30, 2020 | 07:20 PM
Ndfastln's Avatar
Ndfastln
That's easy - so they can charge more!!
Old Mar 30, 2020 | 08:14 PM
Hoyt 1911A1's Avatar
Hoyt 1911A1
Hopefully someone who knows Rushmore stuff real well can correct me if I'm wrong, but a dealer explained it to me a while back. Each speaker is a component set, so two channels of an amp are required to drive each speaker. So for each pair of speakers four channels are required to drive them, thus one four channel amp per pair of speakers. If they were good quality speakers and amps then this might be pretty cool, but a lot of folks seem to be disappointed when they go the Boom 2 route.
If we use aftermarket component speakers we can still wind up with one four channel amp per "pair" of speakers, but the aftermarket stuff is more powerful and usually sounds better. Some of the hard core folks here will stuff three amps under their fairing and more in the bags. It all depends on what one wants I guess. For me I am using coaxial speakers and can drive eight speakers well with two four channel amps. It's often a balancing act of how much cargo space we are willing to give up for the additional sound. I have one very large amp that had to go in the saddlebag but I was able to put it on the front facing side of the clutch side bag so it's not too bad.
The MoCo puts the amps in their saddlebags on the back side mounted vertically. This seems pretty cool until that double sided tape gives way. I have actually seen brand new CVOs in dealer showrooms where that tape has given way and the amp has fallen down into the bottom of the saddlebag.
Old Mar 30, 2020 | 09:37 PM
Bonhomme's Avatar
Bonhomme
'The MoCo puts the amps in their saddlebags on the back side mounted vertically. This seems pretty cool until that double sided tape gives way. I have actually seen brand new CVOs in dealer showrooms where that tape has given way and the amp has fallen down into the bottom of the saddlebag"
That's what happened to mine
Old Mar 31, 2020 | 02:43 PM
Hoyt 1911A1
If it were me I'd be tempted to use some of the 3M outdoor rated double sided tape. The thick gray stuff. I have adhered things with that stuff and when I tried to remove it actually ripped off a layer of the wood it was stuck to!
Old Mar 31, 2020 | 07:14 PM
mikes300's Avatar
mikes300
I really think it's because they go out of their way to make sure that none of their stuff is comparable with anything else LOL
cskarns
Audio Systems
Feb 21, 2020 01:08 PM
cshocker
Audio Systems
13
Jan 9, 2020 06:20 PM
Joey Bako
Audio Systems
Sep 4, 2019 01:36 PM
shaneballance
Audio Systems
15
Aug 13, 2018 03:51 PM
Bagger_Vance
Audio Systems
Oct 3, 2013 05:01 PM
