Tweeters
SO I had the issue with my tweeters and removed the TXO crossovers and then found a wire with a "break"in the copper and would only go out when the wire moved in the slightest of movement but not when moving "hard". So anyway, found it and rewired the bike.
I left the wires for the tweeters off and found an old thread on the forum that stated I need a 3.3uf bass blocker capacitor on the positive wire.
My question is, I run the Moto600 and have the AWs off 1&2 channel and Pro6wnds off 3&4. Since the AWs are not nearly as efficient at the Beymas, Can I run the tweeters off the Beymas instead of the AWs? Allowing the AWs the complete power of the channels?
