Amp draw
Old Jun 24, 2020 | 05:16 PM
bikridr69's Avatar
bikridr69
Default Amp draw
Anyone ever have a stinger 700.4 amp just start drawing power when the ignition is off? I put the amp n speakers in back in mid/late April. Sunday n Monday my bike had a lag to start. Didn’t ride Tuesday. Went to start the bike today and the battery’s dead. Did a parasitic draw test, got like 1.3 amps drawing with the ignition off. Pull the fuse to the amp (at the battery) and amp draw goes to nothing (miliamps). I haven’t pulled the fairing yet. That’s next. Am I looking for a short or a bad amp?
Old Jun 24, 2020 | 06:27 PM
marcodarq's Avatar
marcodarq
make sure that the remote trigger wire is not staying powered up. in turn keeping the amp powered also. if the trigger is not hot and the amp is still drawing, bad amp. check to see what supplies power to your trigger.
m
Old Jun 25, 2020 | 07:22 AM
bikridr69's Avatar
bikridr69
m
that’s what I was afraid of. So I’ve had this installed since mid April. And just recently started having the problem. So I don’t believe the remote wire is constantly hot. Or I would’ve had problems with dead battery right after I installed it. So I’m kinda leaning towards the amp went bad. But wasn’t sure if that’s what would happen if it went bad. I’ll pull the fairing off after work today and see if I can figure it out.
Old Jun 26, 2020 | 09:52 AM
Hoyt 1911A1's Avatar
Hoyt 1911A1
Along the lines of what Marco said set up your meter to check current draw (parasitic drain) again and unhook the trigger/turn on wire going to the amp. If you still have draw then probably the amp is bad. If you don't then your trigger wire may have shorted against something that is always hot. Worth a try.
Old Jun 26, 2020 | 10:56 AM
Fireball Jack's Avatar
Fireball Jack
With the high price of the stinger these days I would run the power wire through a 40 amp relay. They are very cheap and will fix your problem.
Amazon Amazon
Old Jun 27, 2020 | 10:01 PM
Hoyt 1911A1
Good idea Jack. Those old Bosch five pin ice cube relays are handy little devices. I never thought of running an amp feed through one but they offer similar devices with even higher current ratings if needed.
laman22
Apr 3, 2020 12:24 AM
Ragz Ultra
Audio Systems
Jul 11, 2016 07:51 PM
DeputyLoud
Audio Systems
32
Jun 20, 2016 07:02 AM
wiguy
Audio Systems
Mar 15, 2016 09:39 AM
silverman9345
Sep 27, 2012 01:07 PM
