Battery question
Old Nov 1, 2020 | 11:58 PM
sponger's Avatar
sponger
Originally Posted by Hoyt 1911A1
Thanks for the replies folks. Lot of good information there.
I got to thinking about the tender like y'all said. I'll try to check and see how high of a voltage it floats at. I remember decades ago I worked in a battery charger manufacturing plant. That was before the phrase "battery tender" was coined. They used to call them float chargers. Anyhow the engineers always tested the daylights out of every design with the customer's battery packs because they said it was critical that the chargers not float at too high of a voltage. They said it would greatly shorten the life of the battery.
The funny thing is back when I bought the Harley battery I was having trouble with starting the bike hot. On another forum everyone swore that my battery was the problem even though I told them I could hear the compensator sprocket clunking in the primary and the starter clutch screech when the comp kicked back due to it's slop. I think I replaced the Interstate battery that was in there to see if the Harley battery would magically repair the worn out comp and starter clutch. Lo and behold it didn't. To solve my hot start issues I had to replace the comp AND the starter drive. Once I did that all starting problems went away.
Soooo.... Last night I put that Interstate battery back in which hadn't been on a charger for over a month and the bike fired right up. So now what I'll do is try to stay off the bike for a few days to make sure something isn't periodically draining the battery. I don't think that is the case though because after sitting for a while the at rest voltage of that Interstate battery was noticeably higher than the Harley one. I think what I may do is get one of those tender leads that has the LED on it that flashes when the battery gets low. That way I will only plug a tender up when the battery actually needs a charge.
Y'all let me know if I am going about this wrong.
With all that in the works (keeping in mind I am not going down the Lithium road) what are some of y'all favorite brands for AGM batteries?
Thanks again for the help.
curious about why not go lithium?
Old Nov 2, 2020 | 08:49 AM
Hoyt 1911A1's Avatar
Hoyt 1911A1
Just plain too much money, simple as that. I don't take home what the politicians are paying folks to stay at home.
Old Nov 2, 2020 | 11:56 AM
sponger's Avatar
sponger
i understand that. I know others dont want to spend the cash for the more expensive one and went with the cheaper Antigravity lithium. I havent heard of any reviews though.
Old Nov 2, 2020 | 02:15 PM
Hoyt 1911A1
In looking around at AGM batteries I seem to be seeing two CCA ratings. Around 385 to 400 and for a few dollars more lots of companies list 500 CCA units.
I looked at a Drag Specialties premium battery rated at 500 CCA and found out in the reviews that Yuasa makes it for them. I tracked down that part number through Battery Mart and found it there for $179.95 with free shipping.
USA-Made Motocross Platinum GYZ32HL AGM Maintenance Free Powersports Battery
That's the same cost as the Harley 400 CCA battery. Seems to have good reviews, if the Interstate unit I put back in there flakes out any time soon I might try one.
On a side note I checked the float voltages on the two battery tenders I use. On my old Wide Glide I have a Harley branded unit and it floats at 13.1 volts. The Shumacher that I always had plugged up to the Geezer Glide had a float voltage of only 12.5 volts. I wonder if the Shumacher just charged the battery and shut off without maintaining it? When I unplugged the Shumacher after it said the battery was charged and plugged up the Harley unit it went straight into charge mode. The funny thing is if the battery was low the Shumacher would charge it up real quick every time.
Old Nov 2, 2020 | 03:43 PM
lefty33's Avatar
lefty33
Hey Hoyt...for what it's worth, I had this Drag Specialties battery in my 12 Ultra Classic. It came in the bike and was still there 6 years later when I traded the bike. It's only 385 CCA but always was there when I needed it. And that's up here in the north. It had to perform in cold/cool spring & fall. Only time it spent on the tender was the long, cold, dark months of winter. Can you tell I'm not looking forward to the next few months?
https://www.denniskirk.com/drag-spec...prd/200849.sku
Old Nov 2, 2020 | 03:50 PM
TriGeezer's Avatar
TriGeezer
Are you sure the Shumacher is really a tender and not a trickle charger}?
Old Nov 2, 2020 | 04:09 PM
mrmagloo's Avatar
mrmagloo
I bought my last Yuasa back in 2013. Lasted 7 years with a Batteryminder set for AGM. Just bought another in June, and it's that same part number GYZ32HL. Got it for around $130 shipped. Great battery, imho.
Old Nov 3, 2020 | 04:55 AM
Outkast6991's Avatar
Outkast6991
Braille 3121 can be had for around $225
Old Nov 3, 2020 | 06:23 AM
InthewindMN's Avatar
InthewindMN
Make sure your charger is a 750 ma output. If it’s higher it will shorten the battery life if left on.
Old Nov 3, 2020 | 08:58 AM
Hoyt 1911A1
Thanks y'all that's a log of good options. I hadn't really heard of the Braille brand before. It seems like a slight compromise in that they recommend it be left on a tender, but seems to have above average cranking power. To those of you that have used that brand, have y'all noticed that you couldn't let the bike sit for long off of a tender?
