Whim ?
Old Jan 1, 2021 | 07:32 AM
DwayneH's Avatar
DwayneH
Veteran: Canadian Forces
Default Whim ?
I really hate to start a thread to ask this, but I looked through the relevant forums for a sticky on abbreviations. Thought I had seen one at one point, but not able to find it now.
Anyhow, what is WHIM? That's a new one for me.
Old Jan 1, 2021 | 07:39 AM
McClendons's Avatar
McClendons
Stage III
Wireless Headset Interface Module........the bikes bluetooth module that should be factory stock......
Old Jan 1, 2021 | 07:50 AM
DwayneH's Avatar
DwayneH
Thank you! Pretty sure my 2010 will not have that. Once I pick it up (dealership delivers it), I'll be able to look for myself.
Old Jan 1, 2021 | 07:39 PM
YPD485's Avatar
YPD485
It is stock on the CVO's and works great.
Old Jan 1, 2021 | 08:31 PM
GearheadMike's Avatar
GearheadMike
WHIM? I thought it was what made you buy multiple Harleys!
Old Jan 1, 2021 | 11:12 PM
TriGeezer's Avatar
TriGeezer
No..your 2010 will not have one. And it’s only compatible with ‘14 and later touring models.
Old Jan 2, 2021 | 06:52 AM
smitty901's Avatar
smitty901
WHIM is another tool or toy depending on your point of view. I have had on from the week they came out. No your 2010 will not have one. Not designed to work with the old radio. Lot of miss information about the WHIM out there.
What it does is allows the total wireless interface with a wireless head set both directions. If the head set is HD enabled it can also provide stereo sound and have many of the function control by the radio rather than have to mess with heard set.
You would not know if a bike has one by looking it goes under the faring. One way would be find the update mini USB. On factory install it is by the USB plug depending on the bike. Installed after the bike was built the Mini USB is normally in right side cover.
But many run it other places. On the RG some of us run it under the right speaker cover. Easier to run and use if needed. . Note there has only been 1 WHIM update so it is not needed often.
You can add some blue tooth function to your older radio check out Iron cross. They can do some useful thing to your radio.
http://ironcrossaudio.com/
Old Jan 2, 2021 | 12:58 PM
DwayneH's Avatar
DwayneH
Thank you for the feedback.
Old Jan 3, 2021 | 05:37 PM
mikes300's Avatar
mikes300
you can just go to the setup menu on the HU if it shows rider and passenger headset you have one, if not, it's not there.
Just Dave
Mar 19, 2015 07:51 PM
FXSTS93
Jul 25, 2010 01:31 AM
Amzie
Apr 25, 2008 07:51 PM
anubisss
Nov 19, 2006 11:56 PM
