GTS compatibility
Old Jun 4, 2021 | 09:34 PM
Wolfmiester's Avatar
Wolfmiester
Default GTS compatibility
If I upgrade from a 6.5 GT to a GTS, will my XM, GPS, and CB work on my 2014 FLHTCU?
Old Jun 4, 2021 | 09:46 PM
Dsm Limited's Avatar
Dsm Limited
XM module will transfer
GPS is included in the GTS
The cb to me is unknown. If cb is optional on 19up Ultras and Limited models, I'd say yes.
Old Jun 5, 2021 | 01:19 PM
lefty33's Avatar
lefty33
The same (76000486A) Bike-to-Bike Communications Kit (CB) fits 2014 to current, so yes.
Old Jun 6, 2021 | 10:41 AM
Wolfmiester
Default Thx
Thanks
Old Jun 7, 2021 | 08:19 AM
Hoyt 1911A1's Avatar
Hoyt 1911A1
I had YouTube playing in the background and this video from NVS audio came up detailing the slight differences in the various bezels of the newer GTS units compared to the older Boom GT ones. Might be some good info for someone looking to put a GTS unit in an older Rushmore bike. The presenter shows that they can be installed in the older bikes, but sometimes a little trimming of the fairing may be necessary on some bikes to get a flush fit.
Old Jun 7, 2021 | 01:28 PM
30glock's Avatar
30glock
The bezels are Identical to the GT, If your installing a unit made for a Batwing into a RG, then yes you would have to snip of 4 or 5 tabs inside the faring where the radio sits so it can be flush. I did this to my 15 CVO RGU, as when I ordered my GTS the only one available was for the Batwing, fit like a glove and it was all plug and play. Also my CB works, XM module from GT Fit the GTS, With CarPlay you now. have 4 maps to choose from. If you order the correct unit for your bike no trimming is required.
Old Jun 9, 2021 | 08:54 PM
Ssitruc's Avatar
Ssitruc
I pulled a GT out of my 16 RGU, put a GTS in it... I plugged the GT's Sirius Module into the GTS, used the GT CB module with the GTS, and the GPS/Nav is actually a part of the GTS head unit, like it was on the GT head unit.... PLUS I had the one HD amp under the GT head unit in the fairing, now it is also hooked to the GTS.... all of it works with the GTS just like it did with the GT. Of course I had to have the stereo flashed/authorized and configured for my systems setup by the dealer.
Old Jun 16, 2021 | 07:16 PM
Airborne350G's Avatar
Airborne350G
Can you tell me what the dealer did in order to get the GTS to work on yours? My dealer is saying that they need to install my GTS in a 2019+ bike to flash it first.
Old Jun 16, 2021 | 08:24 PM
Dsm Limited
Dsm Limited , Today 01:22 AM
Global Moderator
If you buy a retro fit radio from the dealer, no fiddle flashing.
If you buy a used 2020 or 2021 with the newer updates, no fiddle flashing.
If you buy a used 19 or 20 with the early flash, it has to go in a GTS bike and have the latest update done prior to installing in an 18 down bike.
Edit Quote
Old Jul 10, 2021 | 09:43 PM
Wolfmiester
Global Moderator
Edit Quote
Thanks DSM, I just got mine flashed and debating on going further.
my new GTS is from a RGS and I have a batwing. Modifications have to be done unless....
I trade with someone.
XM, GPS, & USB works well. CB is a work in progress.
Oct 21, 2015 03:18 PM
jkane13
Sep 20, 2013 05:01 PM
shekmark
Jan 30, 2009 02:24 PM
shekmark
Jul 30, 2008 04:20 PM
saweet96
Mar 12, 2008 09:51 PM
