Audio Buzz
Have a Hogtunes amp installed with 2 sets of 6.5” speakers and a set of tweeters, along with a fair amount of accessory LED lights - front and rear along with a run/brake/turn modulator…I’m getting a fairly loud buzz from the speakers at very low or no volume. Assuming it’s from a combination of the amplifier and the LED’s or the run/brake/turn modulator; is there a simple fix for the audio buzz to get it to go away?
Side note, I’m extremely happy with the music at mid and high volume. It’s crystal clear at 80mph on the freeway with a full face helmet!
You’re right, the buzzing does go away when I remove it. Hoping to keep it installed as that’s also the rear brake modulator from Custom Dynamics that I really like and actually think it makes me safer out on the road.
Is there anything in the market that will help with the buzzing that allows me to keep the modulator installed?
So this only bothers you when? In the parking lot at full stop with the motor not running? Can you hear it when tooling around town at moderate speeds? Probably not.
There are many reasons why this occurs and we can start the path to resolving it (them?) but is it worth the effort?
If you don't hear the noise when cruising around town or at highway speeds does the noise even exist?
Only you can decide. That decision will determine the amount of time, effort, and money required to put the issue to bed.
In other words don't go looking for trouble that may not exist.
It's your call now.
It's your call now.
just plain john
Audio Systems
13
Sep 5, 2015 05:58 AM
