Rushmore rear speakers
2014 FLHTK stock 25w/ch BOOM
I/we nearly always ride with full face helmets using the HD headsets plugged in. This last weekend we had a bit of a ride where we were around town and played the BOOM using the external speakers. The rear speakers are blown and sound like ****. The high/mid range FREQ is OK but the low FREQ/base just make them rattle...new speaker time I guess.
Except for playing the external system in the garage periodically, the speakers are rarely used...
What are the recommendations from the audio experts here??
1.) Just replace the rears with genuine MoCo and live with it?
2.) Get a much better aftermarket speakers for a bit more $$ and be way ahead?
3.) Replace all four along with an additional amp?
4.) What are your feelings on the BOOM audio upgrades? Worth the $$?
5.) Will adding an amp improve sound through the helmet set speakers?
The audiophiles will **** but I don't want to spend more than about $500 if I don't have too. I also don't want to have to get the ECM flashed every time I turn around. Essentially I just want good sound and don't want to make a hobby out of the system.
THANKS ALL!!!
Paul
Two Biketronics Line Levelers and a breakout harness. With a 10% forum discount the your looking at about $200. So that would leave you with $300 for amp and speakers which is doable with budget components.
So no, you won't find us recommending Boom audio. THANKS ALL!!!
Paul[/QUOTE]
Thanks again...Paul
