Dsp??
Old Aug 16, 2022 | 01:29 AM
21Glider's Avatar
21Glider
6th Gear
Default Dsp??
Ok so I had the speakers replaced, coax in the fairing and mid bass in the rear, added an amplifier and had the stereo flashed. It doesn’t matter how low I turn the treble down it still sounds like too much treble. Do I need a DSP to fix this issue?
Old Aug 16, 2022 | 01:49 AM
travelingypsye's Avatar
travelingypsye
What does your set up cosist of including HU amp and speakers?
Old Aug 16, 2022 | 08:18 AM
Fireball Jack's Avatar
Fireball Jack
I am in the same boat, I have a DSP on the bench in the garage.
Old Aug 16, 2022 | 11:12 AM
Cosmic Razorback's Avatar
Cosmic Razorback
Community Influencer
Active Streak: 30 Days
You have no control without a DSP.
I have a DSR1 and control it from my iPad. You can also use an iPhone. Simple Bluetooth connection and easy adjustment.
I’m no expert, but it’s easy enough that a cave man can use it!
Old Aug 16, 2022 | 12:41 PM
21Glider's Avatar
21Glider
6th Gear
Default Dsp
Thanks I will try the Dsr1
Markm32
Audio Systems
Jun 29, 2016 09:16 PM
Bikerscum
Audio Systems
Apr 6, 2015 06:11 PM
ALUCARD19
Audio Systems
Feb 10, 2015 12:34 PM
gtarca
Audio Systems
Feb 9, 2015 08:13 PM
FLTpilot
Audio Systems
16
Jul 26, 2013 10:11 AM
