Basic Wired Headset Question
Old Aug 30, 2024 | 01:45 PM
cagillett's Avatar
cagillett
New Member
Default Basic Wired Headset Question
Simplest question of the day......I have a 2019 TriGlide with a Boom! Box GTS. I want to use the wired Harley headset. I plug in to 7 plug connector into the port on the gas tank, change the audio routing to headset, and I get no sound. I am sure that there is a simple step that I am overlooking. I appreciate your help.
Thanks!
craig
Old Aug 31, 2024 | 10:06 AM
cycle7447's Avatar
cycle7447
Community Influencer
Thanks!
craig
Yep, I think you are probably missing a basic step. Make sure the volume to the headset is up. One of the easiest ways to do this is - as you noted, plug the headset in, change the routing to headset -and then, use the thumb control on the left-hand side to click up. This turns the volume up.
Let me know if this works - if not, I can share or review a few other things.
Old Aug 31, 2024 | 11:55 AM
TriGeezer's Avatar
TriGeezer
^^^. Yup. Took me a while to realize that each function has it own volume control, when the function is active. Forvintercim, you have to do it while someone is talking.
Old Sep 3, 2024 | 11:18 AM
cagillett's Avatar
cagillett
New Member
With your tips and a little more "playing around", I have it working. Looks like the volume was down to the headphones and a loose connection at the headset itself.
Thanks for your help. I'm a happy camper and down road.
Rcloud72
Audio Systems
Mar 23, 2021 07:43 AM
SteveFLHTK
Audio Systems
Apr 18, 2019 11:34 AM
Offroadmaniac
Audio Systems
May 15, 2017 07:45 PM
tconnell21
2014-2024 Touring Models
Jun 6, 2014 09:47 AM
ashmarc
Jan 19, 2010 07:04 PM
