My 2016 Ultra Boom screen is discolored and yellow. Does it have a replaceable screen protector on it from the factory or was that something aftermarket? I can’t see any exposed edges around it to peel up.
If it still has the factory screen protector on it you'll see 2 small angular cutouts in the top corners of the screen. That's the peel point. If they are not there then someone already removed it.
The 2016 Ultra Boom screen typically doesn't come with a factory-installed screen protector; it’s usually just the screen itself. If it's discolored and yellow, it might be a sign of damage or wear. You could try cleaning it gently, but if the discoloration persists, you may need to consider a screen replacement.
"Bass M" is also advertising a 4 speed transmission for sale
Member @papagotwheels was cheated out of $100 deposit while trying to buy it
Whether that was the work of @Bass-M or an outside scammer is unknown
