Cutting speaker pods
Old Mar 29, 2026 | 04:18 PM
Front Sight's Avatar
Front Sight
Default Cutting speaker pods
Getting ready to install a set of GZ yellow baskets in my Road Glide. Is there a template available to make the cuts? I found one on the Soundz website but it doesn’t print out to the correct size. Wanting to keep the holes as small as possible and not look like a rabid bagger did it. Thanks!
Old Mar 29, 2026 | 08:30 PM
Babyboy's Avatar
Babyboy
Heat the pods with a heat gun where the magnet is touching the pod. Push the speaker into the pod to form around the magnet. No cutting needed. I used this method more than I can remember how many I have done.
Old Yesterday | 05:09 AM
Bass-M's Avatar
Bass-M
I’d trace the grille itself instead of messing with templates. Tape it on, mark the inside edge with a fine tip, then cut just inside that line. Gives you a clean fit without extra gap to cover.
Old Yesterday | 01:42 PM
Front Sight
Bass-M, I think you misunderstand what I was referring to. This is fitting the speaker inside the pod. The size of the magnet requires the pod to be cut. I will be using the stock speaker grills.
Old Yesterday | 06:17 PM
chopper_man's Avatar
chopper_man
The pod does not need to be cut for the magnet to fit. As mentioned, you heat the pod up where the magnet goes with a heat gun and you push in the speaker, the magnet will mold the hot plastic around it. Heat, push, heat, push. Usually takes a couple/few times to get it just right. You do you tho...
Old Yesterday | 09:45 PM
Babyboy's Avatar
Babyboy
@chopper_man
Some people dont listen and would rather chop up their $20k+ bike for a $1000 investment
Old Today | 05:31 PM
Front Sight
Originally Posted by Babyboy
@chopper_man
Babyboy, you steered me right when I did my last bike so I see no need to go against your advice. Heating up the pod it shall be! Thank you!
Old Today | 08:11 PM
Babyboy's Avatar
Babyboy
I wouldn't point someone in the wrong direction. Just take your time and do multiple heats on the pods if the speaker doesn't go in the first time.
nicholsnuts
Audio Systems
Jun 3, 2018 12:05 AM
BOSOXFan
Audio Systems
Aug 12, 2013 04:30 PM
bald1der
Jan 1, 2012 03:38 PM
Roadglide3
Jul 5, 2008 11:01 PM
DeathWind
May 18, 2007 10:26 AM
