Mode SEL switch
Old Aug 11, 2012 | 10:50 PM
wtsrg08's Avatar
wtsrg08
5th Gear
Angry Mode SEL switch
I need help. Today while riding I accidentally pressed the MODE SEL switch and the radio went to WB, Now I can not get it to return to radio or cd. Riding a 2008 Road Glide. Any help would be Appreciated.
Old Aug 12, 2012 | 06:12 AM
Iron Cross Audio's Avatar
Iron Cross Audio
Former Sponsor
What happens when you hit the mode select now?
Do you still have volume control?
Do the faceplate buttons still work?
Old Aug 12, 2012 | 09:35 AM
wtsrg08's Avatar
wtsrg08
5th Gear
When I push the mode select now the radio stays on WB and I do have volume control. The faceplate buttons do not work. I can inject the CD and reinstall but nothing changes, still on WB. I can move from WB1 thru WM7.
WTSRG08
Old Aug 12, 2012 | 12:30 PM
Iron Cross Audio
Former Sponsor
Clarify please.
You say your faceplate buttons don't work, but you can eject the CD??.
Is it just the preset buttons not responding?
can you turn the unit on/off?
Old Aug 12, 2012 | 01:53 PM
wtsrg08's Avatar
wtsrg08
5th Gear
I can eject and restall CD but the CD would not play, just the WB.
I could turn the unit on and off.
Now for the rest--- I disconnected the battery , reconnect it and the unit is now working better. The radio will play, the up and down on the mode select buttom work. If I put in a CD it will play, but the CD only. If I push the mode select buttom nothing happen, it will not switch to radio or WB. Do I have a bad mode select button?
Thanks for the help.
Old Aug 12, 2012 | 01:56 PM
Iron Cross Audio
Former Sponsor
That would be the first place we would check
papabear64
Aug 23, 2017 06:43 AM
tinsnips
Jun 6, 2017 09:41 AM
alrosse
2014-2024 Touring Models
Jan 7, 2015 01:22 PM
apamike
Audio Systems
Jul 10, 2014 02:22 PM
royston
Sep 22, 2011 08:20 PM
