Wiring Suggestion
Hello all, I'm going to be running the pbr300x2, mm651 2.7 ohm front, hogtunes 2 ohm in the rear pods. The tour pack will be detachable. I have a few thoughts on how I think I should wire this set up but I would like to see if anyone has any better ideas. Thanks
Yes I am. Here's my thought. Wire left channel front and rear in a series, when I remove the tour pack I'll use a "jumper" to connect the positive and negative to then make it parallel too the front only. Do the same on the other channel.
turbo54
Feb 22, 2007 05:04 PM
