Does anyone else have this problem
Old Apr 10, 2013 | 07:09 PM
FatDadTwo's Avatar
FatDadTwo
Default Does anyone else have this problem
Hi
I just installed my full new stereo
Sony 310 HU 4 polk speakers one 22 amp
Took it for my first long ride tonight had the ipod loaded inside the head unit. After about half hour the ipod kept cutting out. When I went throught the controls on th hu it said no device attached. I hope it is not a defect. I just went out to the garage and tried it again and it is working fine. Please help if you can.
Thanks
Old Apr 10, 2013 | 07:37 PM
GLACIERPEARL's Avatar
GLACIERPEARL
What model IPOD ?
Old Apr 10, 2013 | 07:39 PM
UltraWalt's Avatar
UltraWalt
Do you have the Classic ipod and if so, those will skip when going over bumps, railroad tracks and so on.
Old Apr 10, 2013 | 07:45 PM
Strait's Avatar
Strait
Check where the plug plugs In for corrosion the least little bit will make it do crazy things my I phone did it. And the moisture just come from me sweating through my pocket. Just an option to check unlikely but it can happen.
Old Apr 10, 2013 | 07:48 PM
Strait's Avatar
Strait
[QUOTE=Streetglide Walt;11149383]Do you have the Classic ipod and if so, those will skip when going over bumps, railroad tracks and so on.[/
I agree I didn't know which model but I have also heard this from someone else.
Old Apr 11, 2013 | 04:19 AM
GLACIERPEARL
Classic IPODs have a spinning hard drive, like a computer. All others have a 'flash' drive.....that's why I asked...
Old Apr 11, 2013 | 06:39 AM
FatDadTwo's Avatar
FatDadTwo
It is my iphone 4s. I also have 4th generation touch that I havent tried.
really hoping it isnt the radio
Old Apr 11, 2013 | 06:41 AM
FatDadTwo's Avatar
FatDadTwo
Also do you know how to put my music from I tunes on to a hard drive. I can just plug that into the stereo.
Old Apr 11, 2013 | 06:52 AM
1sweetglide08's Avatar
1sweetglide08
I have the same radio and same problem from time to time. When it happens I press the source button until I get internal USB and then the iPod will read and play again. Doesn't happen all the time.
Old Apr 11, 2013 | 07:29 AM
UltraNutZ's Avatar
UltraNutZ
hmm.. 2+ years now with the DSX 310 and always use iPod, nothing else.. never had this issue. If the head unit is saying no device attached, that means it doesn't see it which leads me to believe you have a connection problem. Check that the USB connection on the adapter is nice and tight. USB is notorious for causing issues like this and it usually only takes a pair of pliers to squeeze the USB plug together ever so slightly.
