Rear speaker outputs..?
I have seen mixed answers as to if my bike has rear speaker outputs at the connector on the back of my stock head unit.
Also if they are there are they just low level outputs for an external amp? Or are they direct to the speaker?
If there is specific rear speaker pins in my stock harness plug on the back of head unit, what pin wire colors would be for the rears?
And if there is an external amp for rear speakers what wires are power and ground? (if applicable)
What i would like to do is wire in an aftermarket stereo to replace my Cassette deck. I am wanting USB/AUX capability..
I was looking at the plug and play harness for Sony that biketronics has and it only seems to use front speaker signal from head unit...The other speaker wires of the harness from them are tied off..?
Any Help on these topics would be a great help, and i will be glad to share any information i can add once i complete the project.
Bike is 2000 Ultra Classic FHTCUI - Thanx again
if you've got rear speaker outputs on your bike the colors will be
brown - left rear +
white/brown - left rear -
green - right rear +
light green/brown - right rear -
brown - left rear +
Ultra is correct. I just did this last night and that was the colors.
If I remember correctly it is pins 3 and 4 for the negative. Pins 10 and 11 for the positive. They are on the right connector coming off of the radio. What I did was cut back the sheathing and splice in about two inches off of the connector.
Good luck.
Good luck.
