Wiring Polk MM651 to the stock radio.
Old May 11, 2013 | 01:49 PM
springer 03's Avatar
springer 03
Default Wiring Polk MM651 to the stock radio.
I have all the wires from the crossovers on the speakers and I'm looking to connect the wires from the crossover imput to the radio speaker wires. I'll be adding the ss nano later. My question is the rt side factory wires are green/black and grey/red. Which wire is +? On the left side the wires are white/orange and green/white. Which is +? also the wires from the crossover are black and black/white. Which is the +?? TIA
Old May 11, 2013 | 02:34 PM
UltraNutZ's Avatar
UltraNutZ
on the crossovers, black with white stripe is +
on the right side, gray/red is +
on the left side, white/orange is +
Old May 11, 2013 | 03:05 PM
springer 03
You're the best! Thanx
In my service manual it shows the gray/red as - ? It just didn't seem right.
Old May 11, 2013 | 03:18 PM
UltraNutZ's Avatar
UltraNutZ
I guess my SM is not the only one misprinted then. Good ole HD...
Old May 11, 2013 | 11:44 PM
Sire2Twins's Avatar
Sire2Twins
Springer,
I started with doing exactly what you are, and while it was really nice over stock, adding the amp really made those speakers sound great. Definitely worth the extra $140 bucks. I'd get that nano now while you have the fairing open and ger ur dun!
Old May 12, 2013 | 08:11 AM
springer 03
Originally Posted by Sire2Twins
Springer,
Fairings open, nano is sitting here, power wire and speaker wire is in the trough, tank is back on, new inner fairing and cap, blue led's in gauges, blacked out turn signal bullets and tank console, blacked out handlebars, basically doing a complete makeover.
Old May 15, 2013 | 03:31 PM
glide_n_around's Avatar
glide_n_around
Where can you find the mm6501's for $140? I have found DB6501's for that but not the MM6501's.....
Old May 15, 2013 | 04:03 PM
springer 03
I bought mine at sonic electronix. MM651's for $139. The MM6501's are mo money.
Old May 15, 2013 | 04:13 PM
UltraNutZ's Avatar
UltraNutZ
I think you misread the post above. What Sire2twins is talking about is the SS PN4.520D amp
Old May 15, 2013 | 06:09 PM
yank721's Avatar
yank721
I got the mm6501 on amazon for 202.00 and by the way the tweeters that come in the box have a bezel with a four prong mounting system that screws into the bezel and if you bend the tabs on the prong just a little it will fit perfectly in the gauge spots with out having to wait for the Harley gauge plugs which are on back order. Thanks un for all your help and patience and you might hear from me tomorrow when my amp comes in lol
kens03
28
Aug 15, 2025 12:26 AM
just plain john
Audio Systems
May 13, 2018 12:09 PM
ShoreRider
Audio Systems
Jul 11, 2015 03:55 PM
Little Mike
Audio Systems
Feb 13, 2015 11:36 AM
jasnusc
Oct 8, 2009 03:53 AM
