AB class amp
Old Oct 7, 2013 | 11:09 PM
D-REY's Avatar
D-REY
3rd Gear
Default AB class amp
Can I use an AB class amp with a 40amp rating on a 2012 FLHTC?
Old Oct 7, 2013 | 11:41 PM
GLACIERPEARL's Avatar
GLACIERPEARL
You could , but I sure wouldn't. What is the name /model of the amp ???
Old Oct 8, 2013 | 01:00 AM
D-REY's Avatar
D-REY
3rd Gear
I have two amps sitting around. JL Audio Slash 300/2(150x2) and SKAR AUDIO LP-100.2(100x2)
Old Oct 8, 2013 | 07:14 AM
UltraNutZ's Avatar
UltraNutZ
These bikes have a very limited amount of output current available to accessories such as amps/lighting/etc. from about 1998 on up, roughly 1/2 the rated output of the charging system is utilized by the bike itself. Class A, B, AB amps are current hungry amps so as GP pointed out, not a good idea. Not to mention they get hot as hell.
Class D, G, H is where you want to be on these bikes.
Old Oct 8, 2013 | 07:21 AM
GLACIERPEARL
Class D amps run more efficiently than an AB amp, getting better use of the power. Class AB amps run hotter too. Neither of the amps you listed will fit under the fairing, ( as far as I can tell),.....but that JL amp is nice.
Old Oct 8, 2013 | 07:55 AM
D-REY's Avatar
D-REY
3rd Gear
Thanks for the info! What is a great 2 channel amp to power a pair of Hertz Hi Energy 6 1/2 coaxials? One that will fit in the fairing. I know that Arc and Rocford will work, but I'm looking for others also.
Old Oct 8, 2013 | 07:58 AM
UltraNutZ's Avatar
UltraNutZ
There are many 2 channel amps that will fit inside the fairing.
SS PN2.350D (could cause FM issues)
PBR300x2
Arc 125.2
Bazooka
out of the bunches available, IMO the best bang for the buck is the 2.350D followed by the PBR300x2.
Old Oct 8, 2013 | 08:11 AM
D-REY's Avatar
D-REY
3rd Gear
I know the pbr300x2 puts out almost rated power, how about the Soundstream.
Old Oct 8, 2013 | 08:34 AM
UltraNutZ's Avatar
UltraNutZ
SS 2.350 blows away the RF power-wise. The only issue is Class D amps are known to cause FM interference issuse. The SS is Class D, the RF is Boosted Rail Technology so you wont have FM issues with it.
Old Oct 8, 2013 | 08:44 AM
D-REY's Avatar
D-REY
3rd Gear
UltraNutZ thanks, I was not sure about the Soundstream because I haven't heard much about there amps since the 90's.
