ipod classic problems
Old Oct 31, 2013 | 05:31 PM
shakrr's Avatar
shakrr
Default ipod classic problems
I have 2 Ipod classics older ones 6 or 7 years old one 120 gb and the other a 160 gb have the latest updates and restored them with apples help which they wouldn't do till they helped me thru it. I have the Sony tune tray and the Ipods will stop playing the songs and skip thru 4 5 6 songs then start playing again, the title of the song is there just no sound it varies different amount of time it starts happening. The radio works when this does happen, I know its not the radio I swapped it out with a new one. Sometimes on a ride when ignition is turned off then on it will stay on playlist but most of the time not. Any one else have this happen? and correct it or are these two toast
Old Oct 31, 2013 | 07:09 PM
Iron Cross Audio's Avatar
Iron Cross Audio
Former Sponsor
iPod classics are hard drive based units.
The hard drives have a hard time handling the vibration of the bike.
try a nano of touch
Old Oct 31, 2013 | 09:42 PM
GLACIERPEARL's Avatar
GLACIERPEARL
So they say...................I've had an IPOD Classic 120gb for 4 summers, and it's never skipped once ........................
Old Nov 1, 2013 | 06:59 AM
UltraNutZ's Avatar
UltraNutZ
same here...
never an issue.
might want to take a look at the USB connection and the adapter connection. Take them apart, clean them with a foam tipped swab and alcohol.
Also take a pair of pliers and GENTLY squeeze the USB ends of the adapter to tighten it up.
Also to determine if it's the connector inside, plug your iPod into the USB connection on the front of the unit.
Old Nov 1, 2013 | 09:55 AM
Munkee's Avatar
Munkee
I have the same exact issue. I can't repeat the issue in my car. And since it used to happen prior to tune tray when I had it mounted on my bars Id have to assume its a hard drive issue. Glad others don't experience it but it sucks a$$. I ended up going 30 GB USB flash but its just not the same. Cheap alternative though.
Old Nov 1, 2013 | 09:58 AM
shakrr's Avatar
shakrr
Its not a skip its just quits playing and then will show the next song for a few seconds till it stops after 5 or 6 songs then it might play or not which I have to switch it off to restart. The connections are clean on the plugs since it is a new unit, the ipods are old and I do have a lot of vibration from the big cam. They work fine in our cages and when the bike isnt runnig. I think I will try a nano. Thanks iron cross
Old Jul 1, 2014 | 07:33 PM
shakrr's Avatar
shakrr
I switched to the nano and it doesn't do this anymore my complaint now is it wont stay on my playlist when on and off at stops also did it with the classic seems no pattern, does it when ever but not all the time?
Old Aug 6, 2014 | 10:46 AM
wingman05's Avatar
wingman05
I am having the same issue with my Nano. I set it for a particular playlist and everything works well, until I restart the bike and it jumps back to the master list. Anyone have a remedy for this?
alex94hd
2014-2024 Touring Models
Aug 3, 2017 10:44 AM
hamah
May 28, 2016 12:39 PM
Webo
Sep 15, 2015 06:47 PM
Krow
May 29, 2011 02:17 PM
Jim Dawson
Aug 6, 2007 01:26 PM
