I use Biketronics BT2180, effortless in constant high volume listening and only get warm to the touch have no problem with FM reception using aftermarket head unit and that el cheapo yellow wire Biketronics call an antenna...but if I can do it again I might go with SS amp instead, it is just too cheap to ignore, never really listen to FM anyway....
I have the Soundstream. I'll trade you amps plus throw a little cash in with the deal.
