Carburetor Related Find discussions on carburetor related goodies here. Swap and trades? Rebuild information and tuning for the pre EFI systems.
Lean running 883/ hammer 1250 conversion?
Old 07-16-2017, 11:37 PM
Lee Gibson's Avatar
Lee Gibson
Lee Gibson is offline
2nd Gear
Default Lean running 883/ hammer 1250 conversion?
Hey guys, a quick run down of what my issue is. I have an 01 883 that I just did the hammer 1250 basic conversion on. I kept stock heads and stock ignition (just retarded it a little). I put in a 45 pilot and 185 main, the bike HATED the 45, wouldn't stay running unless I was at 1/4 throttle and it was puking black smoke, even with the mixture screw at 2 turns out. I put the 42 pilot back in and it ran much better, except it's running lean (plugs are white) and it's popping and back firing on deceleration, even with the mixture screw about 5 turns out. I asked hammer and they had no idea what could be the issue, said they've never seen a bike not like the 45 pilot like mine did. Any one here have some advice of what may be going on? Thanks in advance
Old 07-17-2017, 10:21 AM
grbrown's Avatar
grbrown
grbrown is offline
Received 2,852 Likes on 2,419 Posts
Hi from the UK and welcome to HDF. We have many members with a lot of Hammer 1250 experience over in the Sportster section, so I recommend you call in there.
Old 08-01-2017, 03:48 AM
Ernie McKracken's Avatar
Ernie McKracken
Ernie McKracken is offline
Stage III
Turning the air/fuel screw out(counter clockwise) on some carbs leans the mixture,lets more air thru passage,less vacuum pulling fuel from pilot jet.
Turn air screw all way back in (clockwise) then back out
1 1/2 turn. This is standard factory setting on most CV carbs. Try small adjustments from there 1/2 turns.
Make sure clean carb/good gas flow/ filter first.
Check web for info for best main/pilot jet size for bigger bore.
Old 08-02-2017, 12:32 PM
Zanthamos's Avatar
Zanthamos
Zanthamos is offline
There is also 44 pilot jet size that you can go to as well. You are not restricted to just 42 and 45.
Lee Gibson
07-18-2017 01:41 PM
6bt
03-29-2017 05:04 PM
run1fsr
01-04-2012 09:17 AM
jered
02-16-2010 11:37 AM
hm338
09-07-2007 06:52 PM
Quick Reply: Lean running 883/ hammer 1250 conversion?
