883 Jetting Concerns
Old Jan 3, 2012 | 09:07 AM
run1fsr's Avatar
run1fsr
Default 883 Jetting Concerns
As part of my current project, I removed the carburetor yesterday from my 1996 / 883 for a rebuild. FYI - Stock HD exhaust with baffles punched out. I will be running a fully exposed K&N filter.
Expecting the original jets, I discovered a 45 slow and a 175 main. My initial plan was to keep the stock jets and simply adjust the mixture. All stores closed due to the holiday, I finished the rebuild using what was there and reinstalled the carb. Bike started right up and appears to run fine, but it was too late to tinker with. Tonight I plan to confirm the idle setting and adjust the mixture. Also will replace the spark plugs and monitor to see if I’m running too rich.
Not concerned with the 45 slow jet, but a 175 main just seems too large. I know there are many posts regarding this topic, but I’m curious what set-up others are currently running. Your thoughts please … thanks.
Old Jan 3, 2012 | 11:42 AM
John Harper's Avatar
John Harper
My service manual shows the 175 as standard main jet in all Non-California models. My Cali bike has a 172 supposedly.
John
Old Jan 3, 2012 | 05:14 PM
Nailz's Avatar
Nailz
My 883 had a 42 pilot and a 175 main. It had an SE A/C and slip-on exhausts. I changed the 42 pilot for a 45 and had it about 1.5 to 1.75 turns out on the mixture screw. Ran great and got good MPG. If it matters, I live in GA at about 1000ft elevation.
Old Jan 3, 2012 | 07:58 PM
groovee63's Avatar
groovee63
Stage III
Default reply to rejetting
I was debating about re-jetting also to my 05 sportster 883c...So I did not re-jet. I am currently running screamin eagle slip onz , and sometimes switch back to the much quieter pipes. I did NOT upgrade to a higher volume air filter either.. I simply drilled the metal plug out of the carb and richened it up in steps.. I found out that when I screwed the screw all the way in to begin with, it was only backed out 3/4 of a turn from the factory..So, I tryed several different settings and all worked fine, but, it usually ends up being about 1-1/2 to 2 turns out AFTER seating the screw all the way in >>> (GENTLY SEATED).. I am NOT a mechanic by trade, but I am NOT scared to work on this bike at all.... IT WORKS FOR ME... RIDE ON!!
Old Jan 3, 2012 | 08:17 PM
run1fsr's Avatar
run1fsr
Okay good ... should work fine with these jets once I get the idle set and mixture adjusted. Just too damn cold to mess with it tonight. Thanks !!
Old Jan 3, 2012 | 10:41 PM
SportyPig's Avatar
SportyPig
Those jets sound about right if with the setup you described.
Here are a couple of really good links on carb tuning and re-jetting.
http://www.harley-performance.com/ha...arburetor.html
http://www.harley-performance.com/ha...r-jetting.html
Old Jan 4, 2012 | 06:46 AM
xFreebirdx's Avatar
xFreebirdx
+1
Old Jan 4, 2012 | 09:17 AM
run1fsr's Avatar
run1fsr
Good Info ... Thx !!
Lee Gibson
Carburetor Related
Aug 2, 2017 12:32 PM
6bt
Mar 29, 2017 05:04 PM
true duals
Feb 14, 2014 06:08 PM
jered
Feb 16, 2010 11:37 AM
bad277
Nov 29, 2009 01:59 PM
