Carburetor Related Find discussions on carburetor related goodies here. Swap and trades? Rebuild information and tuning for the pre EFI systems.
Air filter
Old 01-21-2018, 02:10 PM
pilecall's Avatar
pilecall
pilecall is offline
3rd Gear
Default Air filter
Was curious if anyone could answer I bought what I thought was right air filter,apparently I was incorrect. The one on the left is what I need (further research determined part# is 29468-02)it belongs on a 51mm carb that feeds a “Jim’s”120ci. It seems part has been given a new # 29468-02a. Question is will part be the one on left or right in picture.
Old 01-23-2018, 02:58 PM
grbrown's Avatar
grbrown
grbrown is offline
Received 2,852 Likes on 2,419 Posts
Red face
All the letter A on the end indicates is a small change of some sort in the design, or possibly a different supplier, nothing that will change it's size or suitability. #29468-02A is indeed the correct number for a 'AIR CLEANER ELEMENT, 51MM CVH'. If the r/h filter is the correct part number that raises doubts about the l/h one! Have you owned the JIMS engine from new?
Old 01-24-2018, 11:13 AM
pilecall's Avatar
pilecall
pilecall is offline
3rd Gear
bought the bike used in 2010 engine had 2500 miles on it then
Old 01-24-2018, 11:46 AM
grbrown's Avatar
grbrown
grbrown is offline
It would be worth checking an aftermarket website, such as K&N, to see if you can find a similar filter, closer to the size of your old one. If that is what your bike is used to, it's worth looking around, trying to get the same! It might even be worth emailing or phoning K&N, with the dimensions, to see if they have a suitable replacement.
big- mike
08-09-2018 05:55 AM
SnoRider
04-16-2018 12:40 PM
El Chiguete
Exhaust System Topics
01-30-2013 06:50 PM
Bsod
03-14-2011 07:55 PM
HDF Tech
Carburetor Related
10-18-2005 04:02 PM
Quick Reply: Air filter
