Carburetor Related Find discussions on carburetor related goodies here. Swap and trades? Rebuild information and tuning for the pre EFI systems.
Vacuum bypass the petcock
Old Feb 23, 2019 | 05:26 PM
Hoginedgewood's Avatar
Hoginedgewood
Default Vacuum bypass the petcock
i happen to have a dry tank, I have heard horror stories.
I took the valve apart, im thinking if I leave the spring out that might be enough to eliminate a future problem.
Old Feb 24, 2019 | 08:48 AM
Yankee Dog's Avatar
Yankee Dog
Is you goal to get rid of the "no fuel flow until vacuum" function?
Not sure exactly how to do the mod, but I heard if you take the petcock apart and move the spring to the other side, it will act like a normal petcock. I"m pretty sure you move the spring so it keeps the diaphragm open instead of closed. Google will help on that. I have also heard you can remove the guts and use just a solid plate, but again, don't have details.
Or just switch out to a conventional style petcock. YD
Old Feb 24, 2019 | 08:59 AM
bustert's Avatar
bustert
the spring and diaphragm must come out. then you make a gasket for the plate to petcock, if you leave it in, could have issues with flow. i MUST run like that because when i bring the rpm up and the vacuum falls, i cannot afford a lean out.
Old Feb 24, 2019 | 09:19 AM
Architect's Avatar
Architect
Get a Pingel, no reason to monkey around to get a stock part to do something it was not designed to do. Petcocks are not expensive.
Old Feb 24, 2019 | 12:58 PM
bustert's Avatar
bustert
well stock or not, this one has been kicking since 2001. cost dirt a** cheap, keeps it fueled at sustained high speed.
Old Feb 24, 2019 | 02:08 PM
Cobra1's Avatar
Cobra1
Not sure exactly how to do the mod, but I heard if you take the petcock apart and move the spring to the other side, it will act like a normal petcock. I"m pretty sure you move the spring so it keeps the diaphragm open instead of closed. YD
Do this. It works and your engine will not starve for fuel. I have modified two different ones with superb results.
Old Feb 26, 2019 | 03:48 PM
98hotrodfatboy's Avatar
98hotrodfatboy
On my friends sporty, I removed the guts and made a flat aluminum plate and gasket. Works great when in a pinch by you should just get a Pingel as Architect said..
WarRacer
Feb 14, 2017 09:30 PM
Knights2TheEnd
Feb 27, 2014 07:30 PM
jreichart
Apr 8, 2013 07:04 AM
fixxr
Feb 8, 2010 09:29 AM
Bryan TTM
Nov 3, 2006 10:13 AM
