Classic All 'historic' bikes.
chain oiler
Old Oct 1, 2010 | 07:52 PM
1956panhead's Avatar
1956panhead
Stage III
Default chain oiler
Do modern drive chains with O rings require constant oiling? If so, what is the correct method of adjusting the built in chain oiler?
Old Oct 6, 2010 | 06:50 PM
sqdealgeorge's Avatar
sqdealgeorge
Yes they do The O'rings eventually brake and lub is needed I don't like the oring chains Tsubaki standard chain is what I use $40 +or - Last at least 7K miles PJ type chain lube is good Spray every 600 miles and party on
Old Oct 7, 2010 | 09:28 AM
1956panhead
Stage III
Thanks George, do you think I should turn off the original factory chain oiler and use spray chain oil? The factory oiler just sprays engine oil on the chain and it does not stick on the chain and sprays all over the bike. Which way does it turn to shut it off?
Old Oct 17, 2010 | 10:41 AM
sqdealgeorge
I'd shut off the oiler and spray as needed
Old Oct 17, 2010 | 04:01 PM
Dan89FLSTC's Avatar
Dan89FLSTC
Active Streak: 30 Days
Modern o ring chains don`t need to be lubed, the stuff cant get in past the o rings. At least that is what the manufacturers say, but I always lube them anyway. I agree with turning off the passenger oiler...
Old Oct 28, 2010 | 01:12 AM
flh80's Avatar
flh80
On my Shovelheads I have RK O-ring chains, the oiler shut off and have the Crankcase Breather hose mounted right behind the front sprocket over the bottom chain and it spits enough just to keep it from running dry. One has been on now for 18yrs/10k. I never touch only to adj it.
Rusty Axle
Shovelhead
Mar 28, 2018 09:06 AM
dukeinhaler
Ironhead
Aug 27, 2014 08:46 PM
sqdealgeorge
Shovelhead
Oct 22, 2011 08:33 PM
Turbo Flux
Feb 20, 2009 09:41 AM
