carb jetting,HELP
Old Jul 17, 2005 | 10:26 PM
sharkie's Avatar
sharkie
Default carb jetting,HELP
i have put some loud arss pipes on my ironhead 1000 ridged ,,,,,i still have the stock carb on it ,,,,do i need to re jet carb ,,,and does anyone know what size jet i should go with ??????
Old Jul 18, 2005 | 10:57 AM
HDF Tech's Avatar
HDF Tech
Default RE: carb jetting,HELP
I don't know what jetting is in there now or what carb, but if you changed the pipes, you should bump up the low speed by one size and maybe the high speed jet size if you feel any surging, readjust the idle mixture also.
Old Jul 20, 2005 | 07:55 AM
sharkie's Avatar
sharkie
bike runs fine except for high rpm,,,when i get rpm up around 4500 to 5000 ,,the best i could describe it is it spudders a bit [&:]
Old Jul 27, 2005 | 08:14 PM
HDF Tech's Avatar
HDF Tech
You have points ignition in it? Check the gap and set the timing before you attack the carb.
Old Jul 28, 2005 | 11:18 PM
sharkie's Avatar
sharkie
thanks ill check the gap asap
but now i have a dumb question,,
i was putting on a new set of chrome rockerboxes and my idiot dog knocked over the box i had them in so they got mixed uo ,,,my Q is i have two with a whole threw them and two that are solid ,,,,,is this normal?? and if is witch ones go where lol,,, i have a clymer book but it does no show this in them[&:]
Old Jul 31, 2005 | 03:54 AM
fxdxsteve's Avatar
fxdxsteve
isn't there an oil line that goes from the cam chest by the lifter blocks up to the rocker boxes is that what you're talking about?
Old Jul 31, 2005 | 01:41 PM
sharkie's Avatar
sharkie
yes there are oil lines going to rocker boxes ,,,but im talking about my push rods ,,,two are hollow two are solid ,,,i bought this motor running ,,but i replaced rocker boxes with chrome ones ,,,
Old Jul 31, 2005 | 02:22 PM
fxdxsteve's Avatar
fxdxsteve
sorry can't help you there what does the manual say?
Old Jul 31, 2005 | 02:24 PM
fxdxsteve's Avatar
fxdxsteve
ps get a manual from harley they're a lot better IMHO
Romprunner714
Carburetor Related
Jun 16, 2013 10:12 PM
Blakester
Ironhead
Jan 7, 2011 06:34 AM
Tltrump
Exhaust System Topics
Nov 6, 2006 09:58 PM
HDF Tech
Carburetor Related
Jun 25, 2005 05:37 PM
MAGSGLIDE
Apr 22, 2005 05:55 AM
