If you can remove the part and soak it, check out "oxalic acid". Lots of videos on it. Otherwise I do the same as previously mentioned, aluminum foil, mothers mag wheel polish, then a good coat of wax when happy with how the part looks. Keep the wax on it on a regular basis.
Not knowing what is best, sometimes I use the synthetic types of wax, sometimes I use conventional carnauba type waxes.
