removing reflectors
Old Mar 12, 2008 | 10:47 AM
bigirn's Avatar
bigirn
Default removing reflectors
this has probably been asked before but how do you get the tape off of frame that the reflector was stuck to?
[IMG]local://upfiles/47706/4550D87C252544669E738DA32B971B0B.jpg[/IMG]
Old Mar 12, 2008 | 10:48 AM
OhioSkully's Avatar
OhioSkully
Default RE: removing reflectors
Cheap little product called GOO Gone paid $3.50 for it at the hardware and that stuff works very well. I used the goo gone when i removed my fork reflectors and the stickers on my AC cover and it worked very well.
Have also heard guys use WD-40
Old Mar 12, 2008 | 01:27 PM
ricoman's Avatar
ricoman
Goo Gone is good to get the glue residue off. Try fishing line drawn back and forth between the reflector and the surface it's mounted to - this will get it off and then you are good to go with the Goo Gone. Follow up with a good coat of wax.
Old Mar 12, 2008 | 06:23 PM
Dorkman's Avatar
Dorkman
WD-40 and a fingernail does the job.
Old Mar 17, 2008 | 12:35 PM
shagnasty's Avatar
shagnasty
WD-40....give it a minute to penetrate.
Old Mar 18, 2008 | 07:29 PM
skltr's Avatar
skltr
+1 for Goo Gone, works great
Old Mar 26, 2008 | 10:27 PM
BTL's Avatar
BTL
Just used goo gone today on a couple of reflectors, just spray and let it soak in for a couple of minutes then wipe off, it took 2 applications to get it all off but it came off easily, then i just finished wiping it with a little alochol.
Old Mar 27, 2008 | 05:24 PM
SCRider's Avatar
SCRider
Used a Blow Dryer to heat up the area around the reflector, then just peeled it off. Used Goof Off to wipe off the remaining glue residue.
_________________
Old Apr 14, 2008 | 08:00 PM
nridge128's Avatar
nridge128
+1 on the blow dryer, definatly makes the job easier.
Sharkman73
Dec 3, 2012 10:50 AM
stonewall308
Jul 20, 2010 11:31 PM
de79
Nov 24, 2009 10:04 PM
redmustang1990
Jan 5, 2009 02:14 PM
vheflin
Mar 25, 2006 03:52 AM
