rust on chrome
Old May 16, 2011 | 10:23 PM
wildman67's Avatar
wildman67
Default rust on chrome
Long story short I lost my house last year and stuck my bike in a storage unit last minute. When I pulled it out a couple of weeks ago I notices spots of rust all over the Chrome after market front panel behind the headlight and I was pissed! Had the bile 5 years and this was my first problems with rust. Is there anyway to get rid of it ? Thanks.
Old May 17, 2011 | 08:11 AM
Dagoat's Avatar
Dagoat
6th Gear
Hi--since chrome is just plated you have to be very careful when trying to get rid of scratches and foreign material on chrome. The safest thing to try FIRST is a good claybar with some clay lubricant. Spray the lube on the chrome and very gently rub in back and forth and up and down movements, not in circles. Check your bar often to make sure there are no pieces of debris stuck, if so pick them out with needle nose pliers and then rework your bar. Dry with a microfiber towel, check your work and if the rust is gone polish lightly with a good chrome polish. Most bike quys use polish to often--remember chrome is plated and polish is an abrassive--cleaning the chrome is usually all that is needed--you can also wax chrome that does not get hot--pipes and other heated chrome will only melt a good wax--I am a detailer and have done many bikes--patience is your best friend
Dave
Old May 17, 2011 | 09:02 AM
john218's Avatar
john218
You might try WD-40 with a soft / microfiber towel.
Old May 17, 2011 | 08:57 PM
Lost1's Avatar
Lost1
Most good chrome polishes will remove rust- just rub vigorously...
Old May 17, 2011 | 09:26 PM
wildman67's Avatar
wildman67
Thanks! I wasn't sure what to do. Thanks for the reply.
Old May 27, 2011 | 02:50 PM
88bandit88's Avatar
88bandit88
6th Gear
The clay bar is a great idea, Thanks!
Old Dec 3, 2011 | 03:03 PM
Brion B's Avatar
Brion B
Turtle wax chrome polish and rust remover works great.
Old Dec 3, 2011 | 05:31 PM
Captain Itch's Avatar
Captain Itch
Sponsor
Neverdull is another great cleaner..
__________________
www.Captain-Itch.com
Old Dec 3, 2011 | 06:17 PM
LA VIC's Avatar
LA VIC
I'm a big fan of the clay bar but don't think that is the best method. Go to Auto Zone and pick up a can of Never Dull. It's a cotton wadding impregnated with solvent. If that won't take it off without scratching it the chrome is likely pitted. It's great for surface rust and corrosion on chrome and aluminum just like a clay bars is good for over spray and contaminants on paint.
Old Dec 3, 2011 | 07:39 PM
ChopperPop's Avatar
ChopperPop
If the mentioned doesn't work, you can try ultra fine steel wool and depending on if the rust is in a small section (in corners, around bolt heads, etc) you could take clear nail polish or something similar after removing the rust to prevent it from returning. I had to do this on a metric I used to have. I bought some chrome parts from brazil for it and the chroming was terrible on most of it.
TylerBoehm
Sep 22, 2013 10:34 AM
foxtrapper
May 24, 2013 09:50 PM
AFblacksheep
Mar 11, 2010 10:55 PM
chop09
Detailing
Mar 12, 2008 02:21 AM
KeithB
Jun 2, 2007 07:01 AM
