Tuning the Bike
Tuning the Bike
So, I just installed the Screaming Eagle stage 1 intake and tuned the bike with the Superchips Vigilante. Everything appears to be fine, the bike is running great and I love the look of the simple round air filter cover as opposed to that ungodly monstrosity HD installed at the factory. Question, when I add my loud pipes over the Winter do I simply plug the Vigilante back in and repeat the process or do I need to do something different now that I've modified the ECM? Thanks!!
Thanks, no I don't intend to go further than intake and exhaust. My question is simply, can I continue to just plug this device in and run it as I swap out these two components, or does using it require some re-calibration before it is used again. I note it has stored data (my original factory tune). Will this be overwritten with the current tune if I use it again?
