new bars
Thanks for pics and advice, was it an easy swap? Did you use all H.D. OEM parts. Is it a do it yourself swap?
Credit for the idea goes to MaineHD - he and his dad have a pair of '06 DBIs with the same set up
Bars are stock 2006 Night Trains (sorry, don't have part #s handy)
Risers are 6" from Drag Specialties with the smooth caps (clamp bolts are underneath)
Used the original rubber riser bushings, may change to nylon - they wiggle a bit
Have not changed out the cables yet, too busy riding...but suggest you do it all at once. The stock cables are a pain to route and look like ****.
Stock Night Train throttle cables will work. You will need to get a custom clutch cable 4" shorter than stock (unless someone knows of a stock cable thatfits this application)
Is it an easy job? I guess that depends on your wrenching skills. I had no problem but have been tearing apart my bikes for almost 30 years... There are some small and somewhat delicate parts involved (throttle cables, brake switch). I would highly suggest you purchase a shopmanualforany type of work performed on your bike. The left grip can be a challange to get off; all depends on how much adhesive they used at the factory...One more thing - cover your tank to cushion against parts that may bang into it. I used bungee cords to hold my stock bars up from the shop rafters during disassembly.
Hope this helps!
Here's a front view - not exactly a clean look with the stock cables - If you run with a windshield I suppose it would'nt matter...
[IMG]local://upfiles/11891/01E00DC2241C4B5DB63BB1DB328A18CB.jpg[/IMG]
Or you can go ***** out!
