thunderheader install question
Old Jan 9, 2015 | 03:01 AM
IornStreetBob's Avatar
IornStreetBob
Default thunderheader install question
Hey guys im about to order my thunderheader for my FXDB and the instructions say to remove the clutch cover. just a quick question do i need to A get Fluids to replace when i take that cover off and do i B need to mess with the clutch cable at all. i wasn't sure when just removing the cover if you need to loosen the cable or not. well actually im not really sure about any of this so if anyone has some pointers that would be helpful
Old Jan 9, 2015 | 06:35 AM
Vonswanko's Avatar
Vonswanko
I was able to install my THeader with out taking the cover off. I used a long ball allen socket and just loosen the bolts and slide the bracket behind them. If I remember, its notched.
Old Jan 9, 2015 | 07:07 AM
jmb79's Avatar
jmb79
My experience was similar to what Vonswanko reported.
Old Jan 9, 2015 | 08:58 AM
apetterez's Avatar
apetterez
Dont remove clutch cable. Not necessary. Freeze the exhaust gaskets theyll fit easier
Old Jan 9, 2015 | 09:23 AM
IornStreetBob
Is it one of those the bracaket uses like two bolts off the case? So should be ok just removing and putting them back real quick no need for anything?
Old Jan 9, 2015 | 09:24 AM
IornStreetBob
Do you mean quite literly to freeze the new gaskets? I've heard thunderheader can be a pain trying to get everything to go on
Old Jan 9, 2015 | 09:46 PM
c-note's Avatar
c-note
Yes. Suggest you do transmission fluid at the same time. Drain tranny fluid, remove cover, install bracket, replace cover, install exhaust, refill tranny. Also a good idea to get a new clutch release cover gasket at same time.
No need to remove clutch cable, just the release cover. AntiSeize on the exhaust gasket helps them in too. Good idea to freeze them.
Old Sep 7, 2016 | 09:50 PM
DMV11982's Avatar
DMV11982
I am trying to get mine off now, so I can sand it down and repaint them. The BITCH of it for me seems to be the O2 sensors and those two bolts beneath the clutch cover!
Old Sep 8, 2016 | 01:09 PM
619DYNA619's Avatar
619DYNA619
As other above have said, you don't need to remove the cover. One bolt comes out all the way and the other just gets loosened a little. Slide the bracket in and tighten her back up. Done.
I've never heard of the freezer trick for the gaskets but I'll definitely give that a try next time the exhaust comes off.
Ultra Pearl
Jun 2, 2018 10:19 PM
rhd01
Feb 14, 2016 06:04 AM
tomryan
Oct 24, 2010 09:42 PM
r8rs4lf
Oct 13, 2010 12:18 AM
HDF Tech
Jun 30, 2005 09:22 PM
