Engine Mounts
Old Apr 7, 2015 | 08:44 AM
Johnnyh14's Avatar
Johnnyh14
Default Engine Mounts
I read a prior thread but can't locate it again to ask a question. Sorry about doing it here. When I looked at the front motor mount behind the oil filter on my 03 SG it clearly had rubber in the center of the mount. I read a few posters stating the 03 had solid mounts. Would solid mounts have rubber in between the fasteners?
Old Apr 7, 2015 | 09:23 AM
1plumr1's Avatar
1plumr1
'03 touring bikes, rubber mount.
Old Apr 7, 2015 | 10:31 AM
Jesse_81's Avatar
Jesse_81
Rubber motor mounts are what make a Dyna "Isolated". All Dynas, regardless of year, are rubber mounted.
Old Apr 7, 2015 | 12:56 PM
Johnnyh14's Avatar
Johnnyh14
No ****, there is a thread that clearly by several posters stated that the 03 didn't have vibe reduction mounts. At a red light my eyeballs shake just a little but I have owned other Harley's that shook a lot more. Thank's for the replies.
Old Apr 8, 2015 | 06:51 AM
1plumr1's Avatar
1plumr1
'03 with 130K, have changed the front mount three times (they break from vibration, really). You asked about the one behind the filter it's rubber, my last change was to poly, more rigid don't notice any more vibration.
Old Apr 8, 2015 | 06:58 AM
PapaThiele's Avatar
PapaThiele
I was told by the mechanic at the shop that replaced my tires that there is a different (than stock) motor mount that flexes so it does not break. Has anyone installed one? Is it worth the additional expense (assuming it is more expensive, of course it is, right?) I am in need of a new front motor mount so wanting to know if I should spring for the stock or the newer, more flexible version.
Also, I am OK with wrenching but I do not havea bike lift or bike jack, just a regular floor jack for cars/trucks. Is this a job for a shadetree mechanic with a good set of tools (torque wrench, sockets, wrenches)?
Old Apr 8, 2015 | 08:05 AM
tomt's Avatar
tomt
I made a Video on the front motor mount replacement. Check it out to see if you are comfortable doing it yourself.
Old Apr 8, 2015 | 11:56 AM
Jesse_81's Avatar
Jesse_81
What your mechanic is talking about is Polyurethane rather than rubber. No it's not "more flexible" it's actually stiffer. They won't break or decay like rubber does though... or the time it takes to do so is much much longer.
Old Apr 8, 2015 | 01:36 PM
PapaThiele's Avatar
PapaThiele
Thanks for the clarification Jesse. You are right, he mentioned it was different material. The mistake was mine, in that my memory is poor and my ADD is....oh, look...squirrel!!!!
Bigg Lou
2014-2024 Touring Models
27
Aug 2, 2016 11:12 AM
FXDLXSD619
Mar 8, 2016 12:46 AM
LunaticFringe
Apr 2, 2015 08:53 AM
El Chiguete
Mar 23, 2013 12:59 PM
89 FXRS
EVO
14
Dec 17, 2007 12:48 PM
