oops
Old Apr 28, 2015 | 04:02 AM
quickslvr8000's Avatar
quickslvr8000
6th Gear
Default oops
ok so i have found what im looking for yet so any help is appreciated. i just finished installing the rivera primo LED light with integrated turn signals. well after the job was finished all the lights were blinking in the off positon of the key along with the security light, is it tripping the security system, and help and insight would be great.
thanks!!!!!!!!!!!!!
Old Apr 28, 2015 | 04:33 AM
wombat457's Avatar
wombat457
Have you double checked the install to make sure all of the connections are good? It sounds like a short or bad connection some where to me.
Old Apr 28, 2015 | 04:36 AM
quickslvr8000
6th Gear
everything is solid
Old Apr 28, 2015 | 11:17 AM
nevil's Avatar
nevil
No idea what bike you have but maybe the light needs a load equalizer?
Old Apr 29, 2015 | 12:51 AM
Davdoodles's Avatar
Davdoodles
When I changed my rear turn bulbs for LEDs, I had to re-set the TSSM (my blink rate was fast and threw an error code.) It might work for you:
- Pull the front brake lever and hold it on.
- Turn ignition ON. Brake light should now be on.
- Push the left signal button, then push the right signal button immediately.
- This will reset the TSSM.
My blink rate has been normal ever since.
I don't know if yours is the same TSSM as mine (2011) or if the problem is fundamentally different, but hopefully that'll help.
Old Apr 29, 2015 | 08:53 AM
Jason Oates's Avatar
Jason Oates
I didn't have the security system concern, but mine needed a load equalizer, and I picked up two of these when switching to LED (one for the fronts and one for the rear)
http://www.jpcycles.com/product/340-300
rangerider547
Electrical/Lighting/Alarm
May 17, 2016 03:41 PM
SOCALLOWBOY
Jul 27, 2012 11:29 AM
Tee Bagger
Jan 10, 2012 05:58 PM
mrbuck
Jan 19, 2009 09:44 PM
amorton
Jun 5, 2007 02:19 AM
