chain drive conversion
Old May 7, 2007 | 01:52 PM
Htrod02's Avatar
Htrod02
Default chain drive conversion
Has anyone converted to a chain drive? Im gonna do my 97 wide glide and with all the parts,including the tire I can do it for 400 bucks. I will be able to fit a 180 tire on it, just wondering if anyone else has done it?
Old May 7, 2007 | 01:53 PM
voyager1's Avatar
voyager1
Default RE: chain drive conversion
curious,why ?
Old May 7, 2007 | 02:11 PM
Htrod02's Avatar
Htrod02
I like the look of the wider tires and its alot chaeper than doing the tranny offset kit.
[IMG]local://upfiles/25921/9FC2F938EFA8472FA863D9E3FBA08E5E.jpg[/IMG]
Old May 7, 2007 | 02:20 PM
SPECIAL ED's Avatar
SPECIAL ED
It also would give you more choices in gearing, it's alot easier and cheaper to get custom sprockets as opposed to pulleys.Allot of buell guys do this when they go racing.
Old May 7, 2007 | 02:24 PM
Htrod02's Avatar
Htrod02
I just finished putting a stroker motor in her also so I think the strength of a chain would also be good
Old May 7, 2007 | 02:27 PM
voyager1's Avatar
voyager1
gotcha.. was just curious.i understand the "why" now .
Old May 7, 2007 | 09:58 PM
2002fxdp's Avatar
2002fxdp
i'm interested if someone has tried this with a newer model (2000+).
i plan on chain conversion when the twin cam becomes a fire breather..........hopefully
Old May 7, 2007 | 10:35 PM
BlacktopBuzzard's Avatar
BlacktopBuzzard
I have converted my 01 FXDL over to chain drive to accept 180-200mm tire. Not sure about a 97 wide glide, but the 01 FXDL required the fender struts be moved outboard to accept a 8 1/2 inch fender (in my case they were cut and re-welded). Other parts were trans offset sprocket/chain/18 x 5.5 rear wheel/rear sprocket/new axle spacers/etc.
hellonewman
Shovelhead
19
Apr 20, 2020 05:01 PM
LeonidasIssopoulos
Jan 16, 2013 03:20 PM
megametalknot
May 17, 2011 04:34 PM
dynatex
Apr 28, 2011 09:47 PM
francos
Jul 25, 2006 11:05 PM
