So after researching around I've found 1000 different answers. My 05 FXD has a probably never seen a primary case or tranny fluid change (new to me, so I rather do it to be safe). These thoughts are prompted by the bike not wanting to downshift into 1st when moving, giving me a grinding sometimes, so i've stopped doing that unless i'm below about 10mph and I need to start moving again. And occasionally it doesn't like to find neutral or shift smoothly into 2nd gear.
so the question, what should I actually run in the primary case and the transmission. I have easy access to 75W-90 Synthetic gear oil and the high quality ATF VI fluid, but that may not be what's best.
No matter what tranny oil you're running, it's going to grind under those circumstances (downshifting into first while moving above 10 mph.) For the record, Mobil One V-twin in both holes is effective, simple and easy to find.
Aside from the never ending debate on which oil to use, you should plan on doing a complete clutch adjustment when you're done. I don't downshift into first while moving but if that's your style it may be easier with the clutch set up properly.
